Hello, I am a new user.
I own a VW Transporter T4 Van.
My gear is a VW 02B, in my case CCY type.
Do you know if, in a 02B Gear box, to change the 5th gear from Z=0.7 to 0.694 ,
I can just swap to the 02G311361G gear i.e. from 45 to 49 tooth ?
Basically I have VW Transporter T4 with a standard VW 02B Gear (CCY type gear)
with the 5th gear Z= 34:45 = 0.756
I did see that in the Vw T4 TDI (EEZ / DQR gear), year 2000 ,
VW used the same 02B type gear but, for the 5th gear Z=34:49 = 0.694
I do know that many people change the Z to 0.68 of the 5th gear installing 2 gear pieces (small and big pinion) and the gasket of a different (02J) VW gear.
As I did notice that actually the same 02b needs only the 49 tooth gear
I am wondering if it will be ok to change only the 5th gear big 49 tooth pinion without replacing both 34 and 45 tooth gears..but only one installing the pinion: 02G311361G
What do you think?
In case kindly let me know. Thanks !
Max.
Here some references:
www.t4-wiki.de/wiki/Getriebekennbuchstabe#1991_-_1996
http://www.myturbodiesel.com/1000q/multi/5th-gear-swap-VW.htm
http://autopartmaster.com/en/?actio...er%202000%20%D2%F0%E0%ED%F1%EC%E8%F1%F1%E8%FF
PS: thanks a lot for your very interesting article:
What do you think?
Max.
