injection pump removal or ALH pump swap writeup, water pump writeup, intermediate shaft seal writeups are up
http://www.myturbodiesel.com/1000q_how_to/a3b4/injpumpswap.htm
ALH injection pump or injection pump removal - to clear some things up, I don't suggest a pump swap unless you: can afford to have your car down for long, feel like getting every last drop of efficiency out of the car, plan on putting an 11mm head on it.
It's nowhere near economical to just replace the pump for a leak or to restore lost efficiency. Just remove and reseal if you have a leak. However, if you want to move to an 11mm head, this is a good idea. In addition, if your pump is truly bad and you need a new one, buying a "take off" pump that someone is selling off an ALH can be more economical than buying a used one and then having it rebuilt.
http://www.myturbodiesel.com/1000q_how_to/a3b4/intermed_shaft.htm
http://www.myturbodiesel.com/1000q_how_to/a3b4/waterpump.htm
water pump removal and replacement and intermediate shaft seal replacement - these used to be 1 writeup but I split them into 2 just to keep them focused and I had more notes to add. It's possible to remove the whole intermediate shaft by loosening 2 motor mounts, raising the engine a little and pulling the shaft straight out.
