So basically when it rains my add blue light comes on and then the check engine Light come on. The warning says to fill add blue or the car won’t start in 600 miles. Here’s the kicker, add blue is full. So I drive the car for a few days and the codes clear. I believe the check engine codes are a combination of P138 series.
Now however the mile has clicked down to 100 miles before the car won’t start.
Couple of things here.
1 Electrical issue?
2 can I reset the computer? As a temp fix
205 Golf Sportwagen DEF problem
I'm confused about the title, 205 the year as this crap new forum doesn't show car spec.put your car spec in your signature that will show on every post?
