Has anyone seen a write up on changing timing belt on 2015 golf tdi or jetta tdi. Other than what is in the shop manual? I know where I can get parts and tools.
Thanks
You need to post the engine code of the data sticker not the timing belt cover as that misses a letter off. I've copied all the info ElsaWin says for loads on newer TDI-CR engines.
Your car spec says 2001 Jetta TDI why do you want this info?
ya sorry. I can rebuild a tranny but im not very computer literate. I haven't been able to change my car to my 2015. I thought it was a ea288 but I found a sticker said cvc. Did they put different diesel engines with a different procedure for each or is there only 1 2015 tdi in Canada. thanks
Its pretty simple to change your car spec. Click on your username Personal Details under Car:
I said they miss the letter of the sticker on the timing belt cover.
Manufacturer: VW, Date(s) Used: 07/2014-12/2015, Model: Jetta, Engine Code: CVCA, 110Kw, 150PS, 2.0 Ltr, 4 Cyls, Remarks: North American Region (NAR): Turbocharged Direct Injection Common Rail (TDI-CR) ComfortLine HighLine
