Hey all, is there any way I can reprogram my key I have a 2015 Jetta TDI SE with a push to start or do I need to go to a dealer? Something happened and I can no longer use my keyfob to lock and unlock my car. I have tried the method in the owner's manual which says to press the unlock button on the fob then insert the key into the door and unlock it, but that did not work. Then I also tried to go into VCDS but none of those solutions worked. Thanks!
