1 - 6 of 6 Posts
I have a 10a fuse that blows now and again. When it does it will throw 6 different codes- charge air cooler coolant pump control circuit low, coolant pump 'C' control circuit low, fuel pressure reg 'a' control circuit open, fuel press reg 'b' control circuit/open, oil pressure reg valve short circuit to ground, cylinder head coolant valve short circuit to groud.
It seems to me that if I were going to attemp repairs I should start with the two devices that say are shorting to ground( oil press reg valve and cyl head coolant valve). A short to ground is going to blow a fuse for sure. That's my thinking anyway. It may not be both but may as well replace them both and see if that does the trick( my thought process).
I'm not exactly sure where these two parts are or what they look like. If anyone has a diagram/picture/directions that might show me I would be most grateful.
I know there are service companies that I can subscribe to get the manual but I'm not sure which is the best one. I'm not sure they would show me what I need anyway.
Any help would be great. Thanks.
Robert
I've added to the title as the model doesn't mean much.
The codes I have: P023B00, P26F500, P009000, P229400, P165F00, P199D00, P16C600. All this after I saw the glow plug start to flash and I pulled over to replace the blown fuse. I had previously cleared all the same codes that were stored from the last couple of times it happened because I wanted to be sure it was all coming from the most recent event.
What was that scanned with has there are 2 many 0's on those EODB II error codes?
Discussion Starter #5
Well we just got a recall for the sunroof leaks( which we have had the last couple of years although I think it is the seal between the roof rack and the roof) so when we take it in to the dealer I will have them scan the codes and give them to me.
A dealer diagnostic scan is expensive. In the UK is £70 with a printout of the results.
1 - 6 of 6 Posts
