Hello from Columbus Ohio
2014 Chevy Cruze Diesel. 70,000 miles.
Bought used ...real nice car except for road noise!
Already had it in 2 times for DEF tank replacement and related
ck engine light came on the other day so I hooked up
the Autel tester that I had to buy to do a Manual Regen a year ago.(Wife
only drives a mile each way to work and sometimes we don't get her cleaned out .)
Anyway I hooked up the Autel tester and it pulled 3 codes:
P21DD-00 P21DD Reductant heater 1 current too low.
U0073-00 U0073 Control Module Communication Bus A Off
B048D-06 I forget what that one is
The special warranty covers the DEF system up to 120,000 miles
Question ..Are these 3 codes related so that when I go to a dealer
he is not going to tell me that the other codes caused the DEF problems.??
I cleared that last code and it also wiped out the other codes so I am wondering.
Immediately when I cleared the codes the engine idle raised at least 100 rpms.
Any help appreciated in advance.
New TDI forum member introductions won't fucking connect to change pole to poll
What were those error codes scanned with a generic scanner?
