So for some reason my AC fuse keeps popping it currently runs on a 10 but i upgraded it to a 15 fuse but even that popped. Has anyone else had this issue or can anyone shed some light on this? Its pretty easy to replace the fuse but i would like to solve the issue instead of keep changing fuses?
You need to specify which fuse is blowing not 10A replaced with 15A, do you have the correct fuse and relay layout for your motor?
You need to find the circuit this fuse controls?
Fuse & Relay PDF Files
