Suddenly only my drivers door unlocks with a single button press. Multiple presses unlock all others. How do I fix so all doors unlock with one press? Also be nice to know, how this happened...
Welcome to the forum.
Figured it out,
Funny, when time permits we can think clearly! The configuration found under "convenience" setting was changed, (don't ask me how?!) no recent battery change, but I found precisely the setting needed.
Well you need to explain what you did exactly with a new thread in the correct section in case other members have the same problem?
Discussion Starter #5
On the steering wheel using the 3:00 control, find in the configuration "convenience", viewing the display, change the selection from drivers door to all doors.
