1 - 1 of 1 Posts
New to the forum, first post!
I recently tried to install an aftermarket camera in my 2012 VW Passat TDI. I hooked into the reverse light and ground. The camera didn't work so I took it off. Now my reverse light isn't coming on and I have a dash warning light to check the bulb. Bulb is fine and the tap area I sealed. Checked connector and no power is getting to it. Also checked fuses and none appear to be blow, but light isn't coming on. Passenger side works fine, just not driver side.
Pulled VCDS and get fault code 01518, short to ground. Any ideas or suggestions on how to fix? Also, does anyone know which specific fuse covers reverse lights?
1 - 1 of 1 Posts
