1 - 15 of 15 Posts
I have a 2012 TDI Sportswagon went into limp mode put on a bunch of performance parts . 170 CR turbo .DGS tune ,Malone stage III tune ,EGR cooler ,EGR delete ,rawteck 3 inch exhaust. I use Ross tech my limp mode is boost pressure sensor replaced it that wasn’t it intake manifold pressure sensor replaced it that wasn’t it. Original limp mode was particulate filter clogged ,Soot in turbo, Vehicle was in limp mode prior to performance parts figured I would get rid of all the choking factory parts. I was doing around 75 miles an hour stomped on the brakes in traffic immediately went into limp mode if that is any help thank you any information would be great.
And please don’t chew my ass if I’m posting in the wrong place. Thank you👍
As I've said in your intro.
The last picture I replaced the sensor. I also replaced the sensor that the turbo actuator vacuum line runs two on the dash right behind the battery. Did not change limp mode. With Ross tech I can turn the glow plug light off and the engine light off car runs fine turn the ignition off start the car again right back into limp mode.
And flashing glow plug light and engine light on
Its no good posting pictures of all the error codes you need to post the VAG-COM\VCDS log file in CODE tags, its simple enough.
Discussion Starter #5
Maybe it is easy enough I couldn’t figure out how to post the Full diagnostics I will work on it .thank you very much
Discussion Starter #6
Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 20.4.1.0 HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: 3VWPL7AJ5CM688520 License Plate:
Mileage: 142680km-88657mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72
77
VIN: 3VWPL7AJ5CM688520 Mileage: 142680km-88657miles
15-Airbags -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
Discussion Starter #7
www.Ross-Tech.com
77
As I've said it a simple request now you have posted the VCDS log file.
It will take a while to post those error codes.
I've just approved your VCDS log file.
2013 VW Golf Variant (Jetta SportWagen for the Yanks)
Forum newb here... intently watching this one. Just had a had a hot mess DPF myself and I'm not yet done buying everything I need(want) but your setup is very close.
Release Notes
Discussion Starter #13
I’m not looking for a free fix I’m going to take it to a local mechanic here in the area and I will post what the diagnosis and fix is so other people may have that same information.
Hopefully I can help someone else out
Thanks, Kieth! I did write a post in the intros section, but I'm not seeing it. Cane back tight to post a few pics!
You're not getting rid of me that easily! You guys know too much... About diesels
We don't get rid of anyone providing they make an intro as I've suggested.
There is still no intro from you, make another one?
1 - 15 of 15 Posts
