I replaced the intake manifold and flap motor. I did the adaption procedure for the intake runner. Car will not start. Purged the fuel system 5-6 times. Turns over fine. Here's the last set of codes (non-VCDS scan, didn't have my cable with me, used cheap bluetooth OBD-II scanner) I had prior to replacing the intake manifold/flap motor. 2004/2006 cleared prior to adapting the intake/motor. 2BA6 remains, I'm hoping once I figure out the no-start issue, this goes away with a nice long drive. Any help is greatly appreciated.
Car Scanner ELM OBD2
DTC report
Selected brand: Volkswagen
VIN: 3VWPL7AJ8CM658430
============1==============
P2BA6
Raw code: 2BA6
ECU: Engine control unit
Status: Pending
============2==============
P2006
Raw code: 2006
Status: Pending
OBDII: Intake manifold air control actuator, bank 1 - actuator stuck closed
============3==============
P2004
Raw code: 2004
Status: Pending
OBDII: Intake manifold air control actuator, bank 1 - actuator stuck open
============4==============
11174
Raw code: 2BA6
ECU: 01. Engine control unit
Status: Validated and stored in non volatile memory, Validated fault present at time of request
============5==============
6744
Raw code: 1A58
============6==============
8198
Raw code: 2006
Volkswagen: P247A00: Exhaust Gas Temperature Out of Range Bank 1 Sensor 3
Volkswagen: Intake manifold flap for bank 1 airflow control is closed
============7==============
8196
Raw code: 2004
Volkswagen Arteon 2017-, Passat B8 / Passat CC B8 2014 - : P1CF100: Steuergerät für Momentenverteilung Allrad
Positionssensor Stellmotor nicht angelernt
Volkswagen CR Touareg 2017 - : B172F12: Front external activation
Short circuit to B
Volkswagen Transporter 2020; Crafter NF 2017 - 2019: B201CF1: Supply voltage
Movement sensor open circuit
Volkswagen: Intake manifold flap for bank 1 airflow control hangs open
DTC report
P2BA6
Raw code: 2BA6
Status: Pending
P2006
Raw code: 2006
Status: Pending
P2004
Raw code: 2004
Status: Pending
11174
Raw code: 2BA6
6744
Raw code: 1A58
8198
Raw code: 2006
8196
Raw code: 2004
Short circuit to B
