hello
I had my high pressure fuel pump seize the timing belt jumped and damaged the head.
So I did a complete engine swap and I did change wire harness because my tdi is a 6 speed manual and the engine I got was automatic. New timing belt, pulleys, CP3, new thermostat, and new clutch/flywheel.
Also the rear main seal was leaking and was replaced using the correct tool to get timing gear correctly positioned.
The code that will not clear is P06A3 the other ones will clear but come back up when driven. The car runs good but would still like to figure out what’s causing the issue.
Thx
Saturday,18,May,2019,08:36:12:61484
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4436.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: 3VW3L7AJ0CM408842 License Plate: CBR2814
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 05 08 09 15 17 19 25 2B 2E 37 44 47 56
VIN: 3VW3L7AJ0CM408842 Mileage: 162960km-101258miles
05-Acc/Start Auth. -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 EH HW: 03L 907 309 AA
Component: R4 2,0L EDC G000SG 3523
Revision: 12H14--- Serial number:
Coding: 0050072
Shop #: WSC 83968 804 673350
VCID: 75B7E21909CE346FBDB-8020
6 Faults Found:
001699 - Sensor Reference Voltage "D"
P06A3 - 000 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162923 km
Time Indication: 0
Date: 2019.05.17
Time: 22:46:09
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Temperature: 95.4°C
(no units): 0.0
Torque: -150.0 Nm
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162925 km
Time Indication: 0
Date: 2019.05.17
Time: 23:17:33
Freeze Frame:
RPM: 3105 /min
Speed: 83.0 km/h
Load: 34.1 %
Voltage: 13.76 V
Voltage: 13.76 V
Voltage: 13.76 V
Voltage: 13.76 V
000769 - Cylinder 1
P0301 - 000 - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162927 km
Time Indication: 0
Date: 2019.05.17
Time: 23:19:34
Freeze Frame:
RPM: 2162 /min
Speed: 36.0 km/h
Load: 38.8 %
Bin. Bits: 00100000
Torque: 3.0 Nm
Bin. Bits: 00000000
Ign. Timing: 18.4 °ATDC
000771 - Cylinder 3
P0303 - 000 - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162927 km
Time Indication: 0
Date: 2019.05.17
Time: 23:19:34
Freeze Frame:
RPM: 2162 /min
Speed: 36.0 km/h
Load: 38.8 %
Bin. Bits: 00100000
Torque: 3.0 Nm
Bin. Bits: 00000000
000772 - Cylinder 4
P0304 - 000 - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162927 km
Time Indication: 0
Date: 2019.05.17
Time: 23:19:34
Freeze Frame:
RPM: 2162 /min
Speed: 36.0 km/h
Load: 38.8 %
Bin. Bits: 00100000
Torque: 3.0 Nm
Bin. Bits: 00000000
000770 - Cylinder 2
P0302 - 000 - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162927 km
Time Indication: 0
Date: 2019.05.17
Time: 23:19:34
Freeze Frame:
RPM: 2162 /min
Speed: 36.0 km/h
Load: 38.8 %
Bin. Bits: 00100000
Torque: 3.0 Nm
Bin. Bits: 00000000
Readiness: 1 1 0 0 X
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: B14B400C492200028D1302E8921B0042251400
Shop #: WSC 30799 001 104857
VCID: 7DA7FA393DFE6C2FF5B-8028
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 74
Mileage: 162663 km
Time Indication: 0
Date: 2019.05.15
Time: 00:40:07
Freeze Frame:
Count: 0
Count: 2
Count: 12800
Count: 397
Count: 50944
Count: 0
Count: 766
Count: 0
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 085 0902
Revision: 00085000 Serial number: 0167091423
Coding: 030C0C
Shop #: WSC 00066 000 00000
ASAM Dataset: EV_KESSYPQ35G A02013
ROD: EV_KESSYPQ35G_A02_VW36.rod
VCID: 34311F1D4EB46D674A5-8060
No fault code found.
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 AQ HW: 5C0 820 047 AQ
Component: J301 Klimaanlage 0203
Revision: 2001010S Serial number: 00000000924153
VCID: 6FBBD0716B920EBF777-803A
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0256
Revision: B2066001 Serial number: 04371118121328
Coding: 73994B9A08230F0008382000240884C50082502E6000000030A000000000
VCID: 2F3B1071A7124EBF377-807A
Subsystem 1 - Part No SW: 6R0 959 801 AF HW: 6R0 959 801 AF Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 004 3464
Serial number: --------------------
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AF HW: 6R0 959 802 AF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 004 3464
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H09 0007
Serial number: WRH0004LQG.
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Serial number: 0163787
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 H HW: 6R0 959 811 H
Component: J388__TSG_HL 004 3464
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 H HW: 6R0 959 812 H
Component: J389__TSG_HR 004 3464
Coding: 800000
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 014 0808
Serial number: 003GTM05NFWG
Coding: 00003936
ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
ROD: EV_AirbaVW10SMEVW360.rod
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H10 0045
Serial number: 6940000Y120000DYLT0O
Coding: 303042
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME7B2A236BZZZ2
Crash sensor for side airbag: front passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME084F656BZZZ6
Crash sensor for side airbag: rear: driver side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME011C0819ZZZL
Crash sensor for side airbag: rear: passenger side:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME4F0A0819ZZZ.
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME25196B17ZZZ-
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME06146B17ZZZV
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5C6 920 951 AX HW: 5C6 920 951 AX
Component: KOMBI H04 0604
Serial number: 00000000000000
Coding: 270A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 015F86C9418608CF913-8054
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0256
Revision: B2066001
Coding: 102200
VCID: 70B9D30D7AAC11476ED-8024
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0604
Coding: 000007
Shop #: WSC 30799 001 1048576
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8DC1655CF0EB97209-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 11000201982001
Coding: 4100000000000000
Shop #: WSC 00066 790 50316
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E050D75A09847B73C1-807A
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661467615
Coding: 020000
VCID: 290FFE6999F6208FE93-807C
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 B HW: 1K0 035 274 B
Component: RNS315-NAR H35 0265
Serial number: VWZAZ2M4215505
Coding: 04090001010006000000100A
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_RNS315NARV2UDS A01004
ROD: EV_RNS315NARV2UDS_VW32.rod
VCID: 2313EC41FB5AFADFA3F-8076
Data medium:
Subsystem 1 - Part No: 3AA 919 866 B
Component: NAR_V2 0002
1 Fault Found:
1048669 - Tuner for Satelite Radio
B11CF 53 [009] - Deactivated
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 74
Mileage: 162663 km
Date: 2019.05.15
Time: 00:40:09
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 372B28115342867F6F7-8062
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 HW: 5C6 035 456
Component: KonzernAmp10K H07 0468
Revision: -------- Serial number: EAA083A0016615
ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
ROD: EV_AudioVerst10KanalSTT3.rod
VCID: 6597B259B5EEC4EF0DB-8030
End----------(Elapsed Time: 01:26, VBatt start/end: 12.2V/12.3V)-----------
welcometomyturbodies
After being advised in your conversation.
VAG Error Code: 001699
EOBD II Error Code: P06A3
Fault Location:
Sensor Reference Voltage 'D' - Open Circuit
Possible Cause:
Fuse(s).
Wiring/Connector(s).
Engine Control Module (ECM).
Possible Solutions:
Check/Replace Fuse(s).
VAG Error Code: 16684/15137/10203/4051/000768
EOBD II Error Code: P0300
Fault Location:
Random/Multiple Cylinder(s) - Misfire Detected/Upper Limit Exceeded/Implausible Signal
Possible Cause:
Air Intake System leaking.
Fuel Supply faulty.
Injector(s) faulty.
Ignition Cable(s) and/or Spark Plug(s) faulty.
Ignition coil(s) faulty.
Exhaust Gas Recirculation (EGR) Valve (N18) stuck/open.
Camshaft Position (Hall) Sensor (G40) faulty.
Low compression.
Possible Solutions:
Check Misfire Recognition.
Check Air Intake System.
Check Fuel Supply.
Check Injector(s) and Injector Sealing.
Check Ignition Cable(s) and Spark Plug(s).
Check Ignition Coil(s).
Check Exhaust Gas Recirculation (EGR) Valve (N18).
Check Camshaft Position (Hall) Sensor (G40).
Check cylinder compressions.
Special Notes:
This Diagnostic Trouble Code (DTC) indicates that one or multiple cylinders are misfiring, but the Electronic Control Unit (ECU) fails to identify the cylinder.
Tech Notes:
The P0300 code means that a cylinder(s) is misfiring or is randomly misfiring. Start by checking for intake leaks, intake gaskets are common caused of multi-cylinder misfiring. If no leak are found the next step is to replace the spark plugs. If the problem persist more tests needs to be done to diagnose problem.
When is the code detected?:
The control module monitors the crankshaft speed and has detected a misfire condition.
Description:
When a misfire occurs, engine speed will fluctuate. If the engine speed fluctuates enough to cause the Engine Speed (RPM) Sensor (G28)/Crankshaft Position Sensor (G28) signal to vary, the Engine Control Module (ECM) can determine that a misfire is occurring.
VAG Error Code: 16686/15128/10592/7115/8736/4057/000770
EOBD II Error Code: P0302
Fault Location:
Cylinder 2 - Misfire Detected
Possible Cause:
Lack/loss of power.
Hard start.
Engine hesitation.
Ignition system.
Fuel injectors.
Fuel pressure.
Running out of fuel.
EVAP canister purge valve.
Evaporative emission system.
Low compression.
Base engine problems.
Engine Control Module (ECM) damaged.
Possible Solutions:
Do a compression test.
Read Measuring Value Blocks (MVB) 15 if misfire changes location.
Special Notes:
This feature search for engine misfire in a specific cylinder. Most of the time the cause for a misfire is a lack of combustion in a cylinder due to absence of spark, poor fuel metering, or poor compression.
Tech Notes:
The P0302 code means that the cylinder 2 is misfiring or is randomly misfiring. Start by checking for intake leaks an if no leaks are found the next step is to replace the spark plugs on cylinder 2. If the problem persist more tests needs to be done to diagnose problem.
Description:
VAG Error Code: 16687/10593/6352/4060/000771
EOBD II Error Code: P0303
Fault Location:
Cylinder 3 - Misfire Detected
Possible Cause:
Lack/loss of power.
Hard start.
Engine hesitation.
Ignition system.
Fuel injectors.
Fuel pressure.
Low compression.
Possible Solutions:
Special Notes:
Tech Notes:
The P0303 code means that the cylinder 3 is misfiring or is randomly misfiring. Start by checking for intake leaks an if no leaks are found the next step is to replace the spark plugs on cylinder 3. If the problem persist more tests needs to be done to diagnose problem.
Description:
VAG Error Code: 16688/10594/4063/000772
EOBD II Error Code: P0304
Fault Location:
Cylinder 4 - Misfire Detected
Possible Cause:
Lack/loss of power.
Hard start.
Engine hesitation.
Ignition system.
Fuel injectors.
Fuel pressure.
Low compression.
Possible Solutions:
Special Notes:
Tech Notes:
The P0304 code means that the cylinder 4 is misfiring or is randomly misfiring. Start by checking for intake leaks an if no leaks are found the next step is to replace the spark plugs on cylinder 4. If the problem persist more tests needs to be done to diagnose problem.
Description:
VAG Error Code: 02214
Fault Location:
Tyre Pressure Warning - Lower Limit Exceeded
Possible Cause:
Tyre Pressure Monitoring found a low pressure.
Even though the tyre pressures where checked and topped up and the SET button pressed this error code still logs in the ecu.
Possible Solutions:
Just clear the Diagnostic Trouble Code (DTC) and everything should be ok.
It will be logged again in the ecu if the Tyre Pressure Warning Light comes back on.
Reset Tyre Pressure Monitoring.
VAG Error Code: 1048669/037327/0020/0023
EOBD II Error Code: B11CF
Fault Location:
Tuner for Satellite Radio - Deactivated/Component Internal Failure
Possible Cause:
Digital Satellite Tuner in Demo Mode.
Digital Satellite Tuner not enabled.
XM/Sirius not activated.
Special Notes:
This fault code is only a note, it will disappear once the XM/Sirius Subscription is renewed.
  • Like
Reactions: Kjohan29
