After engine swap check engine light on
6 Faults Found:
001699 - Sensor Reference Voltage "D"
P06A3 - 000 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162923 km
Time Indication: 0
Date: 2019.05.17
Time: 22:46:09
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Temperature: 95.4°C
(no units): 0.0
Torque: -150.0 Nm
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162925 km
Time Indication: 0
Date: 2019.05.17
Time: 23:17:33
Freeze Frame:
RPM: 3105 /min
Speed: 83.0 km/h
Load: 34.1 %
Voltage: 13.76 V
Voltage: 13.76 V
Voltage: 13.76 V
Voltage: 13.76 V
000769 - Cylinder 1
P0301 - 000 - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162927 km
Time Indication: 0
Date: 2019.05.17
Time: 23:19:34
Freeze Frame:
RPM: 2162 /min
Speed: 36.0 km/h
Load: 38.8 %
Bin. Bits: 00100000
Torque: 3.0 Nm
Bin. Bits: 00000000
Ign. Timing: 18.4 °ATDC
000771 - Cylinder 3
P0303 - 000 - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162927 km
Time Indication: 0
Date: 2019.05.17
Time: 23:19:34
Freeze Frame:
RPM: 2162 /min
Speed: 36.0 km/h
Load: 38.8 %
Bin. Bits: 00100000
Torque: 3.0 Nm
Bin. Bits: 00000000
000772 - Cylinder 4
P0304 - 000 - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162927 km
Time Indication: 0
Date: 2019.05.17
Time: 23:19:34
Freeze Frame:
RPM: 2162 /min
Speed: 36.0 km/h
Load: 38.8 %
Bin. Bits: 00100000
Torque: 3.0 Nm
Bin. Bits: 00000000
000770 - Cylinder 2
P0302 - 000 - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162927 km
Time Indication: 0
Date: 2019.05.17
Time: 23:19:34
Freeze Frame:
RPM: 2162 /min
Speed: 36.0 km/h
Load: 38.8 %
Bin. Bits: 00100000
Torque: 3.0 Nm
Bin. Bits: 00000000
Readiness: 1 1 0 0 X
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: B14B400C492200028D1302E8921B0042251400
Shop #: WSC 30799 001 104857
VCID: 7DA7FA393DFE6C2FF5B-8028
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 74
Mileage: 162663 km
Time Indication: 0
Date: 2019.05.15
Time: 00:40:07
Freeze Frame:
Count: 0
Count: 2
Count: 12800
Count: 397
Count: 50944
Count: 0
Count: 766
Count: 0
