1 - 9 of 9 Posts
Engine turned off at 70 miles per hour on cruise control. No dash warning lights. I was able to safely pull to the shoulder on the interstate, popped the hood, nothing out of the ordinary. Checked the oil, radiator was fine. Tried to restart, engine cranked, but would not start. Had it towed to my home town shop and after 2 days, still has not been trouble shooted.
Release Notes
How long is a piece of string?
Thread moved to the correct section as OP can't read sub forum titles as its not a mk4 question.
its possible ruber timing belt broke.?
Discussion Starter #5
UPDATE - Just spoke with VW Dealership and it's the Turbocharger. Not sure on the repair cost but did ask is this a common repair at 157K miles on this year. They said no.
I have same vehicle in Canada i know VW extended there emmissions
(warranty coverage on some of the emmision parts like ("DPF filter, EGR Valve, & Turbo.) so i would ask them if theres any coverage left on the turbo??
Discussion Starter #7
Thank you, I am hoping for warranty coverage. The VW dealership has had the car for 10 days and is still waiting for the part!
1 - 9 of 9 Posts
