1 - 6 of 6 Posts
Hi everyone,
Just bought a used 2012 Audi A3 TDI. When I did the VCDS scan, it showed that there's 4 fault and would like to get help on resolving them. Below are the screenshots of the scan.
8403
First fault:
8404
Second issue:
8405
Third issue:
8406
There's also a radio fault but it's not important.
I do not have a clue as to where to start trouble shooting, so I'm seeking help from those who know. Any input is greatly appreciated and since we are all being asked to stay home for the next few weeks, I do have the time to work on cars and stay productive.
Thank you all and stay safe.
Its not your first post but you have never made an into.
You don't say what the problem your having?
When you post an AutoScan just post all the text in the VCDS log file in CODE tags.
Thanks for the info Keith. I like the new platform and was actually surprised to see it when I logged in a few days ago.
My old trusty red Jetta '06 got into a fender bender a few weeks ago and we ended up just letting it go since it made sense financially.
So now, we have this Black 2012 Audi TDI with about 89K miles, it runs perfect however the current issue that I'm experiencing with it is that the remote FOB seems finicky. Sometimes it works from a far distance but sometimes even if your standing next to the car it does not respond right away. I would have to push the lock button several times. The second thing, this just happened the other day, it stopped making the alarm/beeping sound when you lock it.
That's when I did the VCDS scan (see below). I'm not sure if any of those codes is the culprit, any input or ideas is greatly appreciated.
Code:
Sunday,22,March,2020,13:08:36:32299
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.2 (x64)
Data version: 20200210 DS308.0
www.Ross-Tech.com
VIN: WAUKJAFMXCA021830   License Plate: AUDI BLK 3
Mileage: 142300km-88421mi   Repair Order:
Chassis Type: FM-AU35 (7N0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 2E 37 42 44 46 47 4C 52 55
          56 62 72 77
VIN: WAUKJAFMXCA021830   Mileage: 142300km-88421miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 030 A    HW: 03L 906 019 EJ
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H14---    Serial number: AUX7Z0K6FN405E
   Coding: 0050078
   Shop #: WSC 09101 003 1048576
   VCID: 2C576E9F8F751C2F29-8078
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 9334
   Revision: 05351113    Serial number: 00001106171316
   Coding: 0000020
   Shop #: WSC 06314 000 00000
   VCID: 173DA17326F38FF774-8042
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: 1150400F492400FB881302E792190042BF0C00
   VCID: 7BF59DC3FA9B4B97F0-802E
Address 08: Auto HVAC        Labels: 8P0-820-043.lbl
   Part No SW: 8P0 820 043 BM    HW: 8P0 820 043 BM
   Component: KlimavollautomatH09 0180
   Revision: 000316      Serial number: 8P0820043BM
   Shop #: WSC 00000 000 00000
   VCID: 78FF82CF0BAD608F9D-802C
1 Fault Found:
65535 - Internal Control Module Memory Error
            003 - Mechanical Failure - Intermittent
             Freeze Frame:
                    Fault Status: 00100011
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 191
                    Mileage: 141750 km
                    Time Indication: 0
                    Date: 2020.03.12
                    Time: 06:37:54
             Freeze Frame:
                    Temperature: 13.0°C
Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
   Part No SW: 8P0 907 063 Q    HW: 8P0 907 063 Q
   Component: BCM PQ35  M   110 0719
   Revision: 00110 AF
   Coding: 6E000A0FA01336E4287241E000100D4D401E62AA104DD128E40008840040
   VCID: 428B2027DDF1FA5FF3-8016
   Subsystem 1 - Part No SW: 8P1 955 119 F    HW: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H11 0050
   Coding: 00DD13
2 Faults Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 142194 km
                    Time Indication: 0
                    Date: 2020.03.17
                    Time: 12:33:16
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.75 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
03396 - Supply voltage terminal 30 for central locking
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 194
                    Mileage: 142304 km
                    Time Indication: 0
                    Date: 2020.03.22
                    Time: 00:03:31
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.10 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 0F: Digital Radio        Labels: 8E0-035-593-SIR.lbl
   Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7L0599620
   Coding: 0000100
   VCID: 36634CF7413956FF4F-8062
1 Fault Found:
02635 - Tuner Not Enabled/Activated
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 142194 km
                    Time Indication: 0
                    Date: 2020.03.17
                    Time: 12:33:28
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 Q    HW: 8P0 959 655 Q
   Component: Airbag AU1042 H09 0250
   Revision: --------    Serial number: 003FC001G5PY
   Coding: 303142393041303030374A55304C38503053
   ASAM Dataset: EV_Airba10AURB4 001001
   ROD: EV_Airba10AURB4.rod
   VCID: 50AF1A6F0B9D18CF75-8004
   Seat occupied recognition:
   Subsystem 1 - Part No SW: 8P0 910 339 C    HW: 8P0 959 339 C
   Component: BF-Gewichtss.  H02 0030
   Serial number: 5810000R0000005HJR
   Coding: 000000
   Crash sensor for side airbag: driver side:
   Serial number: 3572DRB40000DBBD31C7
   Crash sensor for side airbag: front passenger side:
   Serial number: 3582DRB40000DBC05A4%
   Crash sensor for side airbag: rear: driver side:
   Serial number: 35128RB4000061D8873L
   Crash sensor for side airbag: rear: passenger side:
   Serial number: 35228RB4000063C89BF/
   Crash sensor for front airbag: driver side:
   Serial number: 35547RB40000653665FQ
   Crash sensor for front airbag: front passenger side:
   Serial number: 35647RB40000653FD44V
Address 16: Steering wheel        Labels: 8P0-953-549.lbl
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Component: J0527           H37 0070
   Coding: 0014142
   VCID: 46833C3731D9C67FDF-8012
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           H02 0100
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
   Part No SW: 8P0 920 983 D    HW: 8P0 920 983 D
   Component: KOMBIINSTR. VDO H02 0150
   Revision: D0H02002    Serial number: 2246K002000714
   Coding: 0272288
   Shop #: WSC 12345 123 12345
   VCID: 3B755DC37A1B8B97B0-806E
1 Fault Found:
00003 - Control Module
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Status: 01100101
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 142194 km
                    Time Indication: 0
                    Date: 2020.03.17
                    Time: 12:33:16
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 080611F2003050
   Coding: 352102
   VCID: 35614BFB9C3F5DE746-8060
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Revision: D0H02002    Serial number: AUX7Z0K6FN405E
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8P0 035 785     HW: 8P0 035 785
   Component: SG ext.Player H08 0100
   Revision: 00000000
   Coding: 020302
   VCID: 74E7B6FFD7C504EFB1-8020
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8P0 035 193 F    HW: 8P0 035 193 F
   Component: RNS-E PU US     H06 0210
   Revision: 0000013S    Serial number: AUZBZ7LD700535
   Coding: 0205645
   Shop #: WSC 22129 444 10246
   VCID: 336575E3524B43D768-8066
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
   Component: Tuer-SG         H04 0101
   Coding: 0001181
   VCID: 4999370B20C7290732-801C
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 232    3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 346776FF574544EF71-8060
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
   Component: AB2 SUBWOOFERBOXH07 0180
   Revision: 00006       Serial number: 92158120769169
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
   Coding: 0001181
   VCID: 4A9B080725C1221F3B-801E
Address 55: Headlight Range        Labels: 8P0-907-357.lbl
   Part No: 8P3 907 357 B
   Component: Dynamische LWR  H01 0010
   Revision: 00000001    Serial number:
   Coding: 0000013
   VCID: 3C775EDF7F158CAFB9-8068
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0205645
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0001176
   Shop #: WSC 06314 000 1012544
   VCID: 428B20271DF1FA5FF3-8016
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0001176
   VCID: 4385252302EBF357F8-8016
Address 77: Telephone        Labels: 8P0-862-335.lbl
   Part No SW: 8P1 862 336 A    HW: 8P1 862 336
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005154150
   Coding: 0011477
End-------------------------(Elapsed Time: 02:40)--------------------------
Discussion Starter #5
Hi Keith,
I did mention the issue that I'm having and that is with the key fob and the missing beep/alarm when you lock it.
Thanks,
Jay
Jay
I have a 2013 A3 TDI that I bought in August and have really enjoyed it. Some of the VCDS codes you have are the same as mine and are not important. The radio one is probably just the Sirus XM radio is not subscribed to. I have the instrument cluster one and I read somewhere that it's just an error that they all show and not a concern. I think the alarm horn is something that is probably a bad alarm horn or wire. I would clear all the codes and see what comes back. Sometimes you can get some weird codes when the battery goes dead from sitting during diesel gate, or when they were working on it. My key fob works fine. Might be the battery in the fob.
Hope this helps.
1 - 6 of 6 Posts
