Car won't turn over. Camshaft sensor went out so I replaced it. It was plug and play so I'm not sure what happened/ is wrong. About 2-3 weeks before Christmas I installed a 250 amp high output alternator and redid my power to battery and all ground wires with 1/0 ofc wire. Other than those two I replaced and primed fuel pump when I changed the sensor. It ran fine up until the camshaft sensor went out and replaced. All codes are low voltage?? Will post full VCDS report shortly
