Engine light just came on today code P2015 Ive noticed lately a misfire while on cruise control.
Intake Manifold Running Position Sensor plastic manifold .......
Big job ?
Hey Mike... I'm experiencing this as well. First, check if you're still covered with Extended Emissions Warranty as this is covered. If it is covered, the usual fix for the P2015 is to replace the manifold motor assembly. If you can get that replaced under warranty, great. Either way, you'll want to google "dieselgeek p2015." There is a part you'll want to get to fix it this issue or as a preventative if you did have the manifold motor replaced. Installing the motor and/or the part is not a big job.
It was indeed an easy fix but alas I ended up selling the car cuz although owning several other Audi's this one had proved to be to much hassle
Ive had my 2011 A3 TDI only since December. It has 111K miles. So far, it's been great, but Im curious what hassles you experienced with yours.
