1 - 9 of 9 Posts
Audi A1 1.6 TDI 77kw CAYC
I have A 2011 Audi A1 1.6 tdi 90k miles with low oil pressure warnings flasing up regularly when it warms up. It's only measuring 10 psi at cold tick over and it doesn't increase with revs. New oil and filter didn't change anything so sump off and found no clogging in the oil pickup mesh. Nothing obvious wrong with the pump and no metal debris found. Big end bearings no play. Is there a pressure regulator in the system that could be operating too low? If so where is this located. Is there a pressure relief valve in the pump that could be passing oil at low pressure? I can't seem to find any info on how the oil pressure is regulated if indeed it is.
Release Notes
I don't have the oil pressure spec for 2011 Audi A1 to hand.
How long is a piece of string?
There are no error codes Keith. The oil pressure should be 30 to 50 psi not 10 psi that I am measuring. The pressure switch operates at 8 psi and is in spec and I've measured this on the bench. It's no surprise I'm getting oil pressure warnings as the pressure is hovering around the low pressure switch setting. Hence I am looking to see if there is a pressure regulator in the high pressure side that could be at fault. I've bought a used oil pump on eBay as a means of eliminating that from the equation so if I get the same low pressure measured values when that arrives and bolted in then I'll know it's not that.
Sorry if I placed this tread in the wrong place.
Cheers
John
I done have AD installed at the moment.
What is the engine codes of the data sticker?
Data Sticker/Options Sticker and Engine Codes
I'm guessing its:
Manufacturer: Audi, Date(s) Used: 05/2010-04/2015, Model: Audi A1, Engine Code: CAYC, 77Kw, 105PS, 1.6 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Common Rail (TDI-CR) 16v Timing belt
Manufacturer: Audi, Date(s) Used: 03/2011-04/2015, Model: Audi A1, Engine Code: CAYB, 66Kw, 90PS, 1.6 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Common Rail (TDI-CR) Timing belt
Discussion Starter · #5 ·
Hi Keith, it's the former. Ie. 77kw CAYC MUM LZ9Y /79Y /YM
Discussion Starter · #6 ·
Do you know if the 2011 A1 77kw CAYC engine has the Control Valve 04L906455B fitted. It's listed as a possible problem area. I think it's for VVT engines but not sure if this is relevant in my case.
1 - 9 of 9 Posts
