here I go ,first time on here ,this is my issue I recently purchasd another cluster as my fuel gauge didn't work ,,so I swapped them ,no start .learnt from that so put my old cluster back in bingo .back to normal minus fuel gauge .o it worked on the other cluster so did the roof ,bonus .so I decided to purchased a drive box immo for the cluster that worked everything ,apart from the continues running .that never worked .so I .put my original cluster back in , and now no lights on the dash a odd licker now and then ,.but now it wont continue running yes it starts then stops .as if the key not reading the cluster now , hmmmmm any ideas please ,
Welcome to the forum.
The title or your text doesn't say which 2007 TDI?
You can't replace the cluster as you have found out it won't run as the immobilizer is on, the warning light in the dash panel should be on, it needs coding or the Secret Key Code (SKC].
hi keith thanks for your reply .vw eos 2007.my address post code is la130qp illtry and get it flahed over next week pal
Ok I've changed the title, I'm curious what the engine code is.
Manufacturer: VW, Date(s) Used: 05/2006-05/2008, Model: Eos, Engine Code: BMM, 103Kw, 140PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD) 8v Timing belt
Data Sticker/Options Sticker and Engine Codes
