GTI 35 Edition , GTD Mk6, Jetta Mk5 BKD 2007
Hi Guys,
My VW Jetta, BKD engine is leaking fuel on passenger side in back of the engine. VCDs scan reveal nothing.
The tandem pump is very dry , but leak droplets can be seen on heat exchange pipe, back of engine bay.
Very strange as I can not locate this. Please advise what I should look at.
Thanks
Al
Diesel leak just insect all fuel pipes and connectors.
Manufacturer: VW, Date(s) Used: 02/2006-07/2008, Model: Jetta, Engine Code: BKD, 103Kw, 140PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD), 16v Timing belt
Manufacturer: VW, Date(s) Used: 05/2004-10/2008, Model: Jetta/Syncro Jetta, Engine Code: BKD, 103Kw, 140PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD), 16v Timing belt
I'll give that a go again , thanks Keith. I have primed all the pumps and all but nothing shows , its only overnight that you get to see the puddle under the car.
Only few blue drops you see is on the back metal pipe that goes from the front -under tandem pump to behind engine between the firewall. Nothing wet on the transmission under the tandem pump .
8634
Discussion Starter #4
Just thinking out loud, what are the chances the fuel cooler is spraying toward engine.? I found some residue on passenger side on plastic under body protection plate
