2006 VW Jetta TDI BRM 305,000 Miles
My car keeps randomly dying when coming to a stop. I can drive a day or two without it happening where it won’t die when coming to a stop. There is no warning that this is going to happen, it just shuts off and then It won’t start back up right away. I have to crank it a few times to get it started. What does happen everytime is that once it is warm I avoid shutting it off until I get to my final destination because it doesn’t want to restart. It cranks and cranks and will finally start. This seems to be only when it is warm. If its been sitting all day/night it will crank right up, I can shut it off immediately and it will start right back up. Im not sure if this is a cam position sensor issue? Crank position sensor? Fuel? I have not scanned it yet but I will hopefully today to give you guys some more information on it. I appreciate the help!
Brandon
Brandon
I would replace fuel filter to start. Then check fuel pump
