1 - 6 of 6 Posts
My A/C has not worked in my 2006 VW Jetta since I have owned it. I recently replaced the compressor valve and re-charged the system with 530 grams of refrigerant but it still is not working. When the switch inside is pressed on it runs for a few seconds then shuts off again. Something in the ECU is telling it to turn back off even though it has no fault codes. Looking for any suggestions or help.
Compressor turns on, not getting (actual) current feedback and don't know where the ECM reads this information from.
Azure Rectangle Font Screenshot Technology
Compressor turns off shortly after it starts
Rectangle Font Screenshot Technology Parallel
I have an mk4 but maybe similar issue. Same symptoms, happened to me twice.
For whatever reason, after a disassemble/ recharge, the high pressure side was tripping a too high pressure fault. You would think the liquid/gas would self distribute throughout the system, but I guess it doesn't always.
I can't remember the source of my info, from here somewhere I think.
With the engine running, AC unplugged from harness and dash control turned on, I put 12v jumpers from a battery directly into the compressor plug and let it run for a few seconds, seems like 30ish. I guess that moved the gas around the system enough that after that the AC worked fine.
I had a similar problem on a 2005 Golf, it was a bad fan. Also check the fuse box on top of the battery. Look and see if any of the connectors are getting hot and melting the plastic. I replaced the fan and also had to replace that fuse box and redo some of the wiring.
All great questions. Do you have the Climatronic Dual Zone control head?
What are your HVAC manifold LP-HP gauges reading when this occurs? Have you replaced the dryer?
Contrary to popular belief, the AC compressor and system is in a constant on state with a computer controlled valve (on the compressor) that varies the quantity of refrigerant to manage cabin cooling. Basically a computer controlled orifice valve of sorts. This valve cannot tolerate any contamination. Specifically, the desiccant leaking out of the dryer into the system, any atmospheric gas, other than R134A, contaminating the system or my favorite the leak stop that cause seals to swell and close to stop leaks… and the seal in the proportioning valve to detach and become unable to regulate refrigerant. That’s some mechanical issues you may relate to. Then there is the computer-controlled, electro-mechanical side. Aka CLIMATRONIC. Unless you have the basic HVAC twisty dials without LCD Temperature displays?
Discussion Starter · #5 · (Edited)
Both fans are good and start to ramp up when a/c switch is turned on. No burnt wires or blown fuses. Fan relay is also good.
A/C controls are standard twisty dials, dryer, condenser, expansion valve, and seals were also replaced when I replaced the valve. Evaporator was flushed, compressor was replaced at the same time but came with a defective control solenoid valve. System was vacuumed down for 45 minutes, leak tested for 45 minutes and vacuumed down and additional hour before it was charged with refrigerant.
Before the compressor kicks on high and low side gauges read 100 psi. When the compressor kicks on high side goes up to 225 low side goes down to 45 @ 104 degrees F ambient
There are no codes that show up on VCDS for the A/C system, however I do get some faults for my can-bus system for the power steering feedback. Below is the scan from my car
Thursday,21,July,2022,18:51:05:50657
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: 3VWST81K46M746436 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWST81K46M746436 Mileage: 417580km-259472miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
44-Steering Assist -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H01--- Serial number: VWZ7Z0E3104993
Coding: 0050071
Shop #: WSC 00066 000 00000
VCID: 6390A6BD4759E603B2D-8036
VINID: 0E69E390805B1067471061031818985F1B
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0021122
VCID: 71BCDCF58DA54493301-8024
1 Fault Found:
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 78AAE1D1EEDF15DBF7F-802C
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000233859
Coding: 14018E234004180000140000001400000008730B5C
Shop #: WSC 23071 444 66570
VCID: 2A0E0B9960F3774BB1B-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 23071
2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 143
Mileage: 417127 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 143
Mileage: 417127 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7E1039808
VCID: 2B000E9D6F096E434AD-807E
3 Faults Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 113
Mileage: 52657 km
Time Indication: 0
Date: 2000.00.00
Time: 00:08:41
02788 - Internal Communications Error
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 254
Reset counter: 183
Mileage: 268249 km
Time Indication: 0
Date: 2000.00.00
Time: 02:22:13
Freeze Frame:
Bin. Bits: 00000010
Bin. Bits: 00000000
01304 - Radio
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 5
Reset counter: 183
Mileage: 268249 km
Time Indication: 0
Date: 2000.00.00
Time: 01:49:07
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 38 AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD03BLXL
Coding: 0013112
VCID: 392C24D59555CCD3C81-806C
Subsystem 1 - Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Subsystem 2 - Serial number: 6332MSME0B7B6753L
Subsystem 3 - Serial number: 6342MSME0C760907D
Subsystem 4 - Serial number: 6351HSME087B0B53C
Subsystem 5 - Serial number: 6361HSME09012134V
Subsystem 6 - Serial number: 63727SME08436773+
Subsystem 7 - Serial number: 63827SME084A0B093
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0000021
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 952 L
Component: KOMBIINSTRUMENT 3HL 4312
Coding: 0023203
Shop #: WSC 23071 444 85660
VCID: 333016FDB739368302D-8066
1 Fault Found:
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105B068773
Coding: 3D3F0B60071002
2 Faults Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 143
Mileage: 417581 km
Time Indication: 0
Date: 2000.00.00
Time: 05:17:45
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 143
Mileage: 417581 km
Time Indication: 0
Date: 2000.00.00
Time: 05:17:50
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 4312
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 36362FE9A44B23AB253-8062
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 1B7803487F6D058F880F048051A0
Shop #: WSC 23071 444 52628
VCID: 74B2D5E1F2B771BBDB7-8020
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 372822EDA341DAA33E5-8062
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 313C1CF54D250493701-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 323E13F948233F8B09B-8066
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D040085511D6073549-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End----------(Elapsed Time: 01:06, VBatt start/end: 12.3V/12.3V)-----------
You are right, there is nothing useful in VCDS for your problem.
Did you add any PAG oil after your A/C flush and complete evacuation? did you add to your system?
sitting in a shaded area with an ambient temperature 103°F. Using that info…
The heat saturation pressure for R134A for
The Low side PSI at:
100°-105°F is 40-45 PSI. Which you meet.
The High side PSI at:
100°F is 315-325 PSI or at
105°F is 330-335 PSI. So you should see 325-330 psi for 103°F
What does your A/C Sticker say for max R134A capacity, under the hood,?
I think it’s 750 grams for this car.
1 - 6 of 6 Posts
