So my girlfriend took her 2006 Jetta to the store today. When she was done shopping, the car wouldn't start. Dash says immobilizer active and the car & key light blinking.
So I told her to go home and get the other key (I figured the battery in the key she had was bad). But its the same with the other key.
I read the immobilizer could lock up if you use a wrong key, (or in this case if the battery in the key was bad).
So how do we reset this bloody thing so it will take the keys again? When I get home from work I'll try to disconnect the battery to see if that helps.
Dealership said I had to tow it to them to get the keys and car re-paired. But it can't be that f'ed up.
Isn't the code hardcoded like a firmware, so it shouldn't lose the codes just like that. Car was working just fine 15 minutes before it refused to start.
Help would be appreciated.
Discussion Starter #2
I managed to solve it by disconnecting the battery. wait for a minute, reconnect battery.
Then put the key in ignition on position for a few minutes. The light stopped blinking and I could start the car.
Thank god...
Disconnecting the battery won't reset the immobilizer.
What error codes are you getting?
