Hi all-
I am trying to diagnose the cooling fan staying running after the car is off and cooled down.
I tried scanning with VCDS. Got nothing initially.
Changed the main cooling fan thinking the fan controller was flaking out, but that did not fix it.
Now I get P1672. Looking at Bentley's online DTC, that is not even listed. Googling, and I am not sure I trust the results is
"18080 cooling fan control 1 open circuit / short with ground p1672 intermittent"
I read the G62 block for the coolant temp sensor, and its like 59-60C, the pop-up in VCDS says 75C is the limit.
What other measuring blocks should I be looking at?
Could it be the collant temp sensor? is that the one under the tandem pump? I tried unplugging it but that had no effect, the fan still runs.
Thanks in advance
sinneD
I recently had a similar issue with my MIKV. BOTH fans ran after shutting the engine off and removing the key! I was blowing fuse #16. Cause was a BAD A/C compressor coil (on a stinking NEW compressor!); coil was shorted. If the circuitry is anything like the MKIVs then you might try disconnecting your A/C compressor wiring harness and replacing the fuse. One can rule in/out the compressor coil by testing the resistance of the coil (disconnect harness and read resistance across the two wires/pins on the compressor [should be in the 3 to 4 ohm range]- a short will show up as a very small resistance number).
