I am trying to help a friend. Could you please check the code P3102 for an Audi TDI - 2006 BRM . Seems to be related to turbo boost level. Engine lacks power. Thanks! I am sure about the mileage, it will be the next post.
2006 Audi TDI BRE
2006 Audi BRM
Audi don't use the BRM only VW. Is that a typo?
Manufacturer: Audi, Date(s) Used: 09/2007-06/2008, Model: Audi A4/S4/Avant/Quattro, Engine Code: BRE, 103Kw, 140PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD) Timing belt
Manufacturer: Audi, Date(s) Used: 01/2006-10/2008, Model: Audi A6/S6/Avant Quattro, Engine Code: BRE, 103Kw, 140PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD) Timing belt
VAG Error Code: 19558/012546
EOBD II Error Code: P3102
Fault Location:
Intake Manifold Flap Motor (V157) - No Signal
Possible Cause:
Hard Shudder when turning OFF the Engine.
Fuse(s).
Wiring/Connector(s) from/to Intake Manifold Flap Motor (V157) faulty.
Possible Solutions:
Check/Replace Fuse(s).
Check/Replace Wiring/Connector(s) from/to Intake Manifold Flap Motor (V157).
Check/Replace Intake Manifold Flap Motor (V157).
Perform Output Test.
Thanks Keith. Probably a typo - I don't remember the engine code.
2006 A6 - TDI engine. ~120K Miles. Low power and black smoke above ~2,000RPM.
Mistery solved: Damaged turbo (seized compressor wheel) was restricting intake air flow. (A lot easier to access turbo on that Audi... ). Cheers!
