1 - 8 of 8 Posts
Discussion Starter · #1 · (Edited)
Hi all, my vacuum nipple came loose that is pressed into the housing of my vacuum pump so I replaced the unit on the side of the head of my ‘05 Passat B5.5. I spilled some fuel when swapping it out and air got in the line. It took a few cranks but it restarted.
Now, it sounds like I am only running on 3 cylinders and I hear a popping noise coming from the engine as if there is a mis-fire.
Any thoughts on how to correct it so it runs smoothly again?
Discussion Starter · #2 ·
It finally threw a CEL and is in limp mode:
2 Faults Found:
16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Freeze Frame:
RPM: 2205 /min
Torque: 180.0 Nm
Speed: 39.0 km/h
Load: 43.5 %
Voltage: 14.29 V
Bin. Bits: 00101000
Absolute Pres.: 2040.0 mbar
Absolute Pres.: 1611.6 mbar
16485 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal
Freeze Frame:
RPM: 2100 /min
Torque: 0.0 Nm
Speed: 110.0 km/h
Temperature: 51.3°C
(no units): 19.2
(no units): 1.59
Temperature: 97.2°C
and some other VCDS readings:
Group 13 - Idle Stabilization
Cyl 1: -3.01 mg/str (this one is way off!)
Cyl 2: 1.15 mg/str
Cyl 3: 0.72 mg/str
Cyl 4: 1.95 mg/str
Group 5: Start Conditions
Injection Quantity: 24.2 mg-str
Group 4: Injection Timing
Injection Start: 5.6 BTDC
Injection Duration 9.2 KW
Torsion Value: 1.0 KW
Group 3: Exhaust Gas Recirculation (EGR)
Mass Air Flow (specified): 475.0 mg/str
Mass Air Flow (actual) 380.0 mg/str
Duty Cycle: 100%
Group 1: Injection Quantity
Injection Quantity: 20.0 ,g/styr
Supply Duration: 8.2 KW
Coolant Temp (G62): 75.6 C
Discussion Starter · #4 ·
I was looking up troubleshooting info and came across this video. He seems to be having a similar issue where one of the injectors is dropping out. Has anyone had experience with intermittent misfiring and these injector connectors on PD engines?
Discussion Starter · #5 ·
So I went through and checked the fuel injector electrical plugs like in the video to see if they were loose... no difference. It still sounds rough, like it's running on 3 cylinders and making a lot of black smoke and soot. Cam and lifters were replaced at 181,909mi. Have 231,597mi now. Cam and lifters looked good when I had the rocker cover off to tighten up the electrical connectors on the injectors.
Thoughts anyone?
I can run more VCSD info if there's something else I should be looking at.
Discussion Starter · #6 ·
So I ordered a new Pierburg Tandem Pump, Fuel Filter, and some Diesel Purge. Going to see if a new pump will deliver better pressure and then use the diesel purge to clean the injectors as best possible without removing them.
Discussion Starter · #7 ·
I received the new tandem pump and installed it, then got it started and running on diesel. After getting it running, I ran some diesel purge through it with no improvement...
It's still running on 3 cylinders, misfiring, and thick black soot is coming out from the tailpipe and accumulating on the rear of the car.
Thoughts on what to tackle next...?
Have you tried cracking the lines loose at each injector while it's running to get the air out? I know air can get trapped in the injectors, which is why it's so hard to get a diesel started after a fuel filter swap.
1 - 8 of 8 Posts
