Hi. I been having issues with my van not having enough power up hills. I hsve the turbo plus the switches, diesel pump 3 times. I really don't no wat else to do. Sometimes is goes into a limp mode will driving and then u hot to pull over and switch off and on for it to clear. Plus it moves uphill like it has no turbo. I also got this error code 00562 oil sensor error, can this cause low boost. Thank you
Wiki pages have been restored as of 7th December, I asked where is the link it should be on top of the main forum
