I have a 2003 Jetta TDI ALH. It’s making a ticking noise which seems to be coming from the valve cover. I just replaced the camshaft and lifters hoping that would solve the ticking. Sadly it did not. I thought maybe there was a pre ignition from a injector so I cracked open each injector one at a time at idle but no change to the ticking. It’s quite a loud annoying tick. It ticks at any rpm. Any ideas of what to look at next?
welcometomyturbodies
I was going to say check the camshaft and lifters but you say you have replaced them.
I don’t have access to a vag-com dongle at the moment. But I don’t have any codes using an OBDII reader. Car runs fine. Just a loud tick as if it was a worn camshaft. The previous owner said it had been ticking for the past 3 years. I’ve owned it for a few months now. If it was valve damage, could it run like it is for 3+ years? I’d hate to be causing some sort of damage whatever is causing the tick.
