My 2003 jetta tdi intermittently Will not start. This has happened 2 times in in the last two weeks. the first time I made 4 attempts to start. When the key is turned on the glow plug comes on and goes out normally. When start is initiated the engine fires up for less then a second then even if starter remains engaged no joy. I tried this 4 times with same results. Next morning the car started normally. Two weeks later the same situation, but the car started on the third attempt. The engine has started normal since.
The car has 194,000 miles and except for clogged manifold (EGR valve) has had no issues. Any ideas?
