car wont start, when started runs bad. replaced the glow plug module made no difference. fuel shut off tested fine. egr cooler is a little dirty. it seems like a timing issue VW dealer says its internal.I disagree it ran fine on my way to do chores need help.
That isn't an easy question to answer as we don't know what has been done or tried.
Post moved to the correct section as OP can't read sub forum titles. ;)
