new to forum... greetings... have a 2003 Jetta GLS Wagon TDI... CEL/P0252/pump noise/no power
having a problem that started with the first use of BioDiesel... I switched suppliers and had some trouble in my '91 300D as well... filters changed and it's ok... not so with the TDI...
Got a CEL (check engine light) - P0252 code... looked it up, guessed filter... swapped filter... good...
for a few days... had some pump clatter...
had injectors cleaned, replaced two nozzles... mileage wasn't great before the biod so with 155k expected... $400, reinstalled injectors... ran great... but then CEL, pump noise, lose of power... talked
to the Diesel shop... recommended Diesel Purge... that worked... for a few more days...
so... I changed the filter again... better for a bit, more Diesel Purge... no happiness... pulled the fuel pickup today, replaced the filter and added a pre-filter like on my 300d... Diesel Purge 2x... still pump noise, CEL again... no power... eliminated the fuel pickup, lines, filter and injectors... all that's left is the pump... $750 for a rebuilt is the best deal I've found, then of course there's a new timing belt, the tools or labor to have it done, new water pump and setup... easily a grand...
NEED to find the special socket so I can pull the top off the injection pump and try to clean that, shop suggested that the fuel metering might be the issue... not worried about tearing into the pump, have had my '91 300D 2.5L TD apart a couple times: http://johnmeister.com/DieselBenz/TECH/124-series/Pressure-Valve-Seal-Replacement/
anyway, looking for more ideas before I pull the IP and send it off or buy a rebuilt pump...
here's the pix from today of the fuel pickup and new filter setup:
http://johnmeister.com/DIESELS/tdi/TDI-fuel-pickup-filter/ALL.html
JUST found the tool on line, need to see if I can find it locally: Part MN3001 - Specialty Socket for Triangular Head Bolts
This unusual tool is necessary for TDI® diesel pump internal repairs. Permits access to the fuel temperature sensor by removing the screws that hold on the top pump cover. Metalnerd® Brand - USA http://www.metalnerd.com/cat05.htm
