1 - 7 of 7 Posts
hello, i have a vw sharan 2002 with the 115hp pd engine, and i have this annoying problem, between 1k and 2k rpms i get no power in 1st 2nd 3rd 4th gear, but in 5th and 6th it seems to be pulling from 1500 rpms. However after 2k rpms ir pulls like a train, no faulf codes, maf sensor is new, turbo is new, egr valve is deleted. I asked a friend to plug in vcds, we drove and the live data was spot on so I really dont know what could be the cause of this, any suggestions?
Who long is a piece of string?
We don't have a Sharan sub forum thread moved to general.
as i mentioned the motor was scanned no fault codes and the live data is good
Scanned with what? Post the results in CODE tags?
If no log file is isn't VAG-COM\VCDS.
Is this your Sharan or are to trying to fix someone else's?
Discussion Starter #5
it is my dads sharan, and it was scanned with vcds, i asked my friend to do it, no fault codes appeared, the only strange thing he told me was that my MAF data is fluctuating and not that linear, but nothing too bad.
How long is a piece of string?
Loss of power at the low rev range could be anything.
We don't know what has been done or tried only what you have said.
Without TDI Wiki you can't search.
Get the VCDS log file of your friend and post it.
You might try adjusting the jam nuts on the push rod on the turbocharger actuator. It changed how my car ran. Don’t go too far though or the car with start to surge.
1 - 7 of 7 Posts
