1 - 6 of 6 Posts
AC was blowing under 40F and I turned the car off. Restarted it and no AC. Idle fluctuates with AC on, so ECU is reacting to compressor not running. Fans do not run on low speed with AC button on. I tested the resistance of the compressor coil and it is out of spec, so it needs replacement. Car has 110 static PSI on the low side, so that should be enough for the compressor to run. The question is, would the coil being bad and preventing the compressor from running also prevent the fans from running with the AC on? If not, I have two problems and will have to troubleshoot the fans and FCM. Will try swapping the coil first. Thanks.
I'm not new, I've posted here before. I did a search, the question I asked "would a bad coil lock out the fans from running when the AC button is on" has not been discussed.
I had similar issues and turn out it was from fuse box on top of the battery. I had to replace it because was melted
1 - 6 of 6 Posts
