I have a problem with my Jetta TDI. While traveling out of state I left Motel in AM and noticed that Car had no power. I have had a CEL off and on for ever, but never the loss of power that I'm now experiencing. I took my Jetta to a dealership and the mechanic said it would take him possibly 2 days to trace down problem due to 5 trouble codes that come back after clearing each time. 16786 (P0402) Exhaust Gas Recirc Flow Excessive Detected Intermittent, 18027 (P1619) Glow Plug relay-J52 Open circuit/short circuit to ground Intermittent, 16629 (P0245) Turbo/Super Charger Wasteg Solonoid A Low Intermittent, 17849 (P1441) EGR vacuum regulator solonoid valve Open circuit/short circuit to ground Intermittent, 16600 (P0216) Injection Timing Control circuit Intermittent. Needless to say, I limped back home to Texas. I have limp repair kit on order and will post results when I install the parts. Anybody ever had this same problem?
The low power has nothing to do with the glow plugs.
Check ALL the vacuum lines. The car is over 10 years old by now and they will be cracked and dried out, probably more so in the South Texas heat. There could be other problems but the vac lines are one of the first things to check. Take a look in the FAQ section for the limp mode troubleshooting article and start working your way through it..
welcometomyturbodies
Also, post moved to the mk4 section since it's more technical in nature.
VAG Error Code: 16786
EOBD II Error Code: P0402
Fault Location:
Exhaust gas recirculation (EGR) system - excessive flow detected
Possible Cause:
Exhaust gas recirculation (EGR valve/solenoid.
Basic setting not carried out.
VAG Error Code: 18027
EOBD II Error Code: P1619
Fault Location:
Glow plug relay - open circuit/short to earth
Possible Cause:
Wiring open circuit/short to earth.
Glow plug relay.
VAG Error Code: 16629
EOBD II Error Code: P0245
Fault Location:
Turbocharger (TC) wastegate regulating valve A - circuit low
Possible Cause:
Wiring short to earth.
Turbocharger (TC) wastegate regulating valve.
Engine control module (ECM).
VAG Error Code: 17849
EOBD II Error Code: P1441
Fault Location:
Exhaust gas recirculation (EGR) valve/solenoid, bank 1 - open circuit/short to earth
Possible Cause:
Exhaust gas recirculation (EGR) solenoid.
VAG Error Code: 16600
EOBD II Error Code: P0216
Fault Location:
Fuel Injection timing control - circuit malfunction
Possible Cause:
Wiring.
Fuel Injection timing control solenoid, Engine control module (ECM).
