Put the engine back to TDC and double check all the marks. It's possible that the injection pump is a tooth off or another sprocket is a tooth off.
If you disconnected the fuel lines it will take some cranking before air is purged out of the line. Crank for no more than 20 and let it rest for at least 30 seconds before cranking again or else it will burn out the starter.
