Battery was drained, had to hook it up to a charger. Now the car won't stay running. The immo2 has kicked in. So I tried reading if it was throwing any codes. Hooked up my Auterra scanner and got no connection to OBDII port. No aftermarket radio is hooked up.
Tested scanner on different car, connects no problem.
Tested K-Line Pin 7. Reads 11.6 volts with no key and with key ON. Blips to ground a few times, while OBDII scanner is plugged in and trying to connect. Pin 16 is getting constant 12v.
