1 - 1 of 1 Posts
I’m currently trying to solve a rough start up issue along with low mpg and Smokey start up.
Recently replaced the timing belt and turbo due to oil pump failure. Since then the start up has been awful like running on 2 cylinders.
Code scan showed codes for injectors so I replaced the injector loom, which made no difference.
Everything I read points to setting up the cam timing with vcds. the question I have is what value should I set it and do I need to adjust both inlet and exhaust cams?
1 - 1 of 1 Posts
