Replaced the timing belt on a 1Z with 265,000 miles. Found the Crank Sproket had worn the flat spot down and was able to rock back and forth until the flat one sproket turned into a point. This is what must have been causing my hard start and poor performance. I used a new crank bolt as I should have on an earlier timing belt replacement
