1 - 7 of 7 Posts
Hi there,
I just bought a 1996 Passat TDI Wagon with 290K. Its been a great car so far but my first project has gone bad
I just replaced the glow plug wiring harness(as it was all cracked) and 4 new glow plugs(3 out of 4 were bad) last night and after completing the work took the car for a spin.
It started right up BUT none of the dash was working (guages,tach,gas,temp) and the check engine light was on. The car ran fine and had good power, but now it cranks for some time and starts eventually but stalls after running for 1 second.
I tried unhooking the battery and hooking it back up to hopefully reset something and it made no difference
It aslo has a weird clicking noise in the dash and the guages look like they're ticking like a clock almost??? I will hook it up to a scan tool when I get home today. Thanks for the Help
The instrument panels can also be damaged if the battery is low and you keep cranking it. Don't keep driving it like this since I think poor grounds could cause the instrument panel to fail sooner or later.
Is the weird clicking noise coming from the firewall in the engine bay? It could be the N75 wastegate control solenoid. This is normal. While you're in there, also clean the contacts on the coolant glow plug relay. This is a strip fuse that commonly burns out.
The clicking noise during a start with low system voltage is typically the cluster gauge stepper motors resetting themselves. The clock and trip odometer will usually reset to zero also. This is the sound of looming cluster damage, so have your battery load tested ASAP unless it is known to be good and fully charged.
Check and clean both the previously mentioned ground and the main cluster ground underneath the battery.
1 - 7 of 7 Posts
