Welcome to the forum.
Well you don't state any year only Passat B5.5 tdi. I've no idea what a B5.5 is but lets take a
Volkswagen Passat (88-96) 1,9D TDI 1993-96 Engine code: 1Z, 100,000 miles service.
Service Time (hrs): 1.90
VEHICLE ON FLOOR
1.0130 Airbags/system - Visual check
1.0160 Horn - Check/report
1.0180 Interior lamps - Check/report
1.0190 Front wiper blades - Check/report
1.0220 Front screen wash - Check/adjust
1.0250 Headlight wash/wipe - Check/adjust
1.0260 Instrument illumination - Check/report
1.0270 Direction indicators/hazards - Check/report
1.0280 Lighting system - Check/report
1.0300 Headlights
VEHICLE FULLY RAISED
3.0100 Front brake pads - Check/report
3.0190 Rear brake pads - Check/report
3.0250 Rear brake drums/linings - Check/report
3.0310 Brake hydraulic system - Check/report
3.0380 Tyre condition - Check/report
3.0410 Tyre pressures
ENGINE BAY OPERATIONS
4.0040 Battery electrolyte level - Check/top-up
4.0080 Brake fluid reservoir - Check/top-up
4.0140 Coolant level/anti-freeze strength - Check/adjust
4.0350 Pollen filter, if fitted - Renew
4.0570 Diesel primary fuel filter - Renew
4.0581 Diesel fuel filter - Drain
4.0760 Auxiliary drive belt/s - Check/adjust
4.1090 Air conditioning
FINAL ITEMS CHECK
5.0040 Engine fault diagnosis trouble codes - Check/report
5.0090 Vehicle locks/hinges - Check/lubricate
5.0110 Headlamp alignment
ROAD TEST VEHICLE
6.0010 Steering free-play - Check/report
6.0050 Transmission - Check/report
6.0060 Brakes
Volkswagen Passat (01-05) 2,0D TDI PD 2003-05 Engine code: BGW, 100,000 miles service
VEHICLE ON FLOOR
1.0010 Brake servo - Check/report
1.0040 Footbrake travel - Check/report
1.0090 ABS warning system - Check/report
1.0100 Fault diagnosis trouble codes - Check/report
1.0110 Instruments - Check/report
1.0140 Switches/controls - Check/report
1.0150 Heater blower - Check/report
1.0230 Rear wiper - Check/report
1.0240 Rear screen wash - Check/adjust
1.0290 Headlight levelling system - Check
1.0300 Headlights - Check/report
1.0320 Body work/paint - Check condition
1.0340 Sunroof guide rails - Clean/lubricate
1.0350 Sunroof seal - Lubricate
2.0010 Engine oil leaks - Check/report
2.0020 Engine oil - Drain/refill
2.0030 Engine oil filter - Renew
2.0100 Gearbox oil leaks - Check/report
2.0110 Gearbox oil - Check/top-up
2.0170 Auto transmission oil leaks - Check/report
2.0320 Front differential oil leaks - Check/report
2.0370 Transfer box oil leaks - Check/report
2.0380 Transfer box oil - Check/top-up
2.0410 Steering joints - Check/report
2.0430 Steering rack/box - Check/report
2.0450 PAS hoses - Check
2.0470 Steering column couplings - Check/report
2.0500 Suspension joints/seals/gaiters - Check/report
2.0560 Drive shaft joints/seals/gaiters - Check/report
2.0580 Rear differential oil leaks - Check/report
2.0590 Rear differential oil - Check/top-up
2.0670 Exhaust system/mountings - Check/report
2.0700 Brake pipe corrosion - Check/report
2.0750 Underbody condition/sealant - Check/report
VEHICLE HALF RAISED
3.0110 Front brake discs - Check/report
3.0120 Front brake calipers/cylinders - Check/report
3.0200 Rear brake discs - Check/report
3.0210 Rear brake calipers/cylinders - Check/report
3.0260 Parking brake cables/linkages - Check/report
3.0410 Tyre pressures - Check/adjust
4.0050 Battery condition/specific gravity - Check/report
4.0070 Washer bottle(s) - Check/top-up
4.0160 Coolant hoses - Check/report
4.0340 Plenum chamber - Check/clean
4.0573 Bio diesel fuel filter - Renew
4.1090 Air conditioning - Check/report
FINAL ITEMS CHECK
5.0050 Service interval indicator - Reset
5.0110 Headlamp alignment - Check/adjust
ROAD TEST VEHICLE
6.0020 Clutch operation - Check/report
6.0030 Vehicle suspension operation - Check/report
6.0040 Engine performance - Check/report
6.0060 Brakes - Check/report
6.0070 ABS function - Check/report
6.0080 Instruments - Check/report
AFTER ROAD TEST
7.0010 Engine Check for leaks
Copywrite Autodata.
If its anything different let me know.
