So I got given an Audi A3 1.9TDIE everything seemed fine seemed low on power but thought this was normal with it being the eco version passed mot etc then when I took it out for a drive the car seemed sluggish like no pull until it got to 3000 rpm then would pull, thought it would need a good blow out so took it for 20 mile run at 60-70mph 2,500-3000rpm then the DPF light came on half way through the journey then went out again, then coming back the glow plug light came on flashing and went into limp mode, I got home turned the car off and on and the light went out and read no codes but the car still felt sluggish, then it came back on again and this time with the engine management light I read the code and it is P0299 and on my reader it says crack in turbo housing or turbo pressure valve, but new to all the VAG stuff so thought I would ask the community so I wasn’t chasing my tail!
What year Audi A3 as we have 2 Audi A3 sub forums?
