After my timing belt ript apart,
I changed cylinder head, gasket and timing belt kitt
It started up , nice idle and nothing wrong.
so i start driving it, after 100m it blow oil out of dipstick. And wont start up, i sound like it only fire on 1 sylinder.
i took off the cylinderhead again and check how it look. Sylinder 1 is dry, sylinder 2,3,4 is wet from unburnd diesel
when i turning the crankshaft by hand and holding over the piston the compression on sylinder 2,3 and 4 goes down in crankcase and out of oil channels
is it posible that piston rings are cracked after piston hit valves in sylinder head?
sorry for bad english!
Discussion Starter · #2 ·
I took pistons out of engine to check, all piston rings was stuck because of soot. Also the oil ring was stuck😅
