Thanks for your help so far - great website!
I have a 2001 Passat TDi 130bhp, 145,000 miles. The car lacks power at lower revs but picks up at circa >2500rpm before, when giving it more boot, going into limp mode. I am told by the previous owner that the reason is over-boost. I have VCDS but due to laptop lead problems I am yet to confirm the fault or run the necessary tests. However the previous owner had replacement N75 and MAS fitted which, he says, gave temporary improvement but the problem returns.
In the light of the the component exchange so far, I suspected sticky vanes or a leaking vane actuator. However, on engine start the actuator pulls the rod sharply up against the stop. So I then decided to assess whether the vane operation was sticky. I detached the actuator from its bracket (two nuts on studs) and, with the engine off, and with the actuator still connected to the rod, I was able to lift the actuator and manually operate the rod to the vanes. To my surprise the force required was minimal. In fact the principal force was the occasional and unavoidable catching of the actuator studs against the holes in the bracket. There was no apparent variation in force along the rod's travel, or any hint of 'slop', varying friction or hysteresis.
This led me to suspect that the vane rod was operating the crank and nothing else: perhaps it was disconnected from the annular ring inside the turbo? So I tried to detect actual vane operation. I failed to remove the flexi to the cat so, instead, I ran the engine at fast idle whilst disconnecting the vacuum line from N75 with and without kinking the line to retain the vac. Occasionally, a slight variation in exhaust note was detectable and, at other times, disconnection or reconnection caused the engine to stutter momentarily. On the basis of this I suspect some or all of the vanes are moving.
My questions please:
For a VNT with perfect vane operation, is the operation force on the rod significant or minimal as I have observed?
Are there any failure modes whereby some or all of the vanes become disconnected from the actuation lever/crank on the turbo and actuation force reduces?
Are there better ways of checking for correct vane operation without the hassle of having to remove the turbo altogether?
Thanks in anticipation for your assistance.
Bartfarst, Redditch, UK
