1 - 6 of 6 Posts
Good afternoon, I recently purchased a 1.9 AHU diesel with a blown head gasket. The shop I took the head to, to be resurfaced, has asked me a bunch of questions that i cannot answer. When resurfacing the head, what are the limits, do they make thicker head gaskets for resurfaced heads or do You use a oem head gasket. New to diesel. Any info would be great. Thank you for your time.
Discussion Starter #5
Hey Keith, I am a firefighter from California, i purchased this vehicle for $200 because I wanted to learn about diesel and try to build a hyper miler in the end.
this is a 1997 VW jetta TDI manual with a AHU motor
At the front of the engine, towards the right hand side, the headgasket has a tab that sticks out and will have 1-3 holes showing on that tab. The number of holes tells the thickness of the gasket. Machining the head deck will change the thickness requirement however and there is a bit of a process for determining that. The machine should should have that information though if they do much auto work
1 - 6 of 6 Posts
