Hello, I have a 2000 VW Beetle with the 1.9 TDI engine. A few months ago I was driving my car and the engine shut off on the highway. The weather was bad and it was cold so I thought it might have something to do with that. I tried to start it back up but it wouldn't start. I looked online and found a suggestion to unplug the MAF sensor. I did that and I was able to get the car home. The next day I plugged the sensor in and the car ran fine. Recently I was having similar issues so I replaced the MAF sensor but that didn't fix the problem.
Currently the car doesn't always start when I try to crank it. If it does start it will usually shut of if I give it some throttle, if I let it warm up it will often run better. I have a Ross-Tech cable and was checking some values with VCDS. It appears that the expected and actual boost values for the turbo are not the same. When I give it throttle the expected boost value goes up but the actual boost value doesn't change at all. On VCDS I checked for fault codes and did an auto-scan but nothing that came up looks like it is related to the problem.
What should I do to troubleshoot the problem?
