My 06 tdi jetta had a small fire on the braided wire for the starter. After changing the starter upon trying to start the car there was no firing of the engine. Car cranks easily but no glow plug light, no check engine light and the PRNDS lights are flashing on the dash. I am completely stuck trying to figure out what to fix.
There is really no such thing as a small fire in an engine bay given the compactness of the compartment and the plethora of wires running around. There are wire bundles which run through the starter area. I would suggest visual inspection of all wires. And I would not power the system until I was certain none were fused to other wires inappropriately.
Had same problem had power to everything else but turned out to be mega fuse try that
The fire could have damaged the harness to the mechatronic causing the flashing PRNDS. Check the connection. It’s just above the starter I believe. If that’s not the case, you need a mechatronic and glow plugs?
