Yesterday I changed my brake fluid and manual transmission fluid in my 2006.5 Jetta TDI 5-speed transmission. The brake fluid change went quite well with the power bleeder.
When it came to changing the tranny fluid, I measured the fluid coming out and only seemed to get less than a quart. When trying to fill the tranny through the upper sensor-plug hole with the same amount, excess fluid came out the inspection hole. I plugged the inspection hole and continued to fill the fluid through the sensor plug towards the top-side of the tranny. Is it normal to get less than a quart of fluid out when draining the tranny?
