Wiki pages have been restored as of 7th Decemeber, I asked where is the link it should be on top of the main forum
A good cranking speed is important.
You have posted in the wrong section, this new forum doesn't allow me to moved this thread.
I just had the same problem on my 2010 Jetta TDI. Only it was "my bad" as I forgot to hook up the ground strap from the DSG to the body after putting a new starter in. Very important to have a good ground or the starter will not work. Another indication of a bad or missing ground is the battery symbol on the instrument panel will first flicker and then go solid, but when you turn the key nothing happens. Hope this helps.
Related Threads
167K posts
102.1K members
Since 2007
