Good morning!
I have a few questions I am sure this group can answer.
Background info; AC was decent since I've owned it. A squeel developed and stopped around the time at the peak of this hot Texas summer!, and the AC would blow cool and hot intermittently, not adequate at all.
So I ordered a cheap ac solinoid , had it vacced. I replaced it, not a hard thing, had it recharged.
AC is cooled to about 60 at vent. It works and not intermittently like before, yet it's not cold like it should be.
Suggestions?! Please! Summer is far from over.
As I've asked in your other post.
A squeal can be a few things fan belt slipping check the tension, the AC compressor packing up.
